Thanks again. You are right that it would be wise to check the switch and starter solenoid to see if they are functioning correct. My thought was that there is no way they would work if they are not connected to anything. First step was to wire everything as it should be to determine where to go next. The wiring has to be in place with a new switch and solenoid to function so if by chance they were in working order, this would be my first step.
Once I can verify I have this wired up correctly, next is to find the faulty link.
