Originally Posted by Rocking416
They are worth the money. But the problem i have has with them is Choke and throttle linkage working correctly as they are not exactly OEM replacement. If you do have to replace the choke arm make sure you watch the detent ball and spring when you un due the choke the choke plate.
Long and short of it . OKAY carburetors but they are throw a way's you do not rebuild them EVER!
Yes, they are cheap enough now to just replace in a year or two.
The first ones to show up like mine, I had to "reclock" the choke lever to the proper index. There was no cheapo carb offered with 100% correct linkages.
But for less than $20 now, there are if you spend the time to look for it.
