A teaser for all of you. I just started a new project tractor to install my Kwik/Way loader on. I want it on a super so I started searching for a super frame or a project tractor. Thanks to Merk I bought a 2182 with the engine tied up so I had my start. The tractor has no plastic so I decided to see about installing a 82 series hood grill etc. I installed a Command twin and the wiring harness from a 1984 I parted out and I have the sheet metal fitted. I was able to keep the tilt wheel and the command dash tower. I did not cut up the hood or side panels. So who wants to guess how I made it fit????? It will look like a factory job when It is finished and painted. If it works out it will also have a single headlight so I can still call it a Cyclops
Pictures later today if I get it all bolted back together. This is just a teaser.
Later
