Glad you found that service bulletin and thanks for all replies. Now I can move forward on this. Now I need to be sure that incorrect plug that was on one side did any damage (RS14YC, threadreach is 6.3 mm longer than oem plug) Most likely will need ignition module (weak spark). I tried downloading the service manual in the technical section, there is none for the 1862.
