-   -   hydro pedal rockshaft (https://www.onlycubcadets.net/forum/showthread.php?t=9953)
william1041200 04-10-2011 06:45 PM
So, on the pedal shaft for a 107 there are 2 separate cast iron rockshaft parts pinned to it. One is long, like about 3 inches long. It has 2 levers on it. One goes to the brake linkage. The other one at opposite end... What is that for? I do not remember removing any linkage from that lever, and I broke it driving the shaft through it. I dont need that bit do I?? Anyone know what it is for?
ajgross 04-10-2011 06:49 PM
Without a picture, I would say it is the neutral return. When you press the brake in, it should return the hydro to neutral.
AJ
william1041200 04-10-2011 06:56 PM
There is a separate cast part for the neutral return linkage. I kinda thought that too, but I know I pulled that linkage from the little guy.
william1041200 04-10-2011 06:57 PM
I will go get a pic or 2 of my mess.
william1041200 04-10-2011 07:13 PM
2 Attachment(s)
ok pics for the issue
darkminion_17 04-10-2011 09:24 PM
Yea that is a mess.
The one on the right goes to the cam plate to put the hydro lever back to neutral.the other is for the brake.The small hole in it is for the pedal return spring.
william1041200 04-10-2011 09:28 PM
Thanks Lew! I can reuse that big piece then. I might just have box #1 with that other piece shipped
