K 161 rebored
Hey All,
New to the forum and I am working on my 1964 70 Cadet that Dad bought new and used for 20+ years. It has a K161 engine and I need the block bored. The machine shop says they can bore it 0.10 oversize and I was wanting to find a good source for a new piston and rings. I found one place here, http://www.petessmallengine.com/html/page_126.html but the 0.010 piston says it's for an 8 hp. K161 or K181. Will this piston fit in my 7 hp K161? Also, will the existing rod still be usable? Thanks, |
I would definitely put a new rod back in it. That old rod has seen too many years of use. NAPA sells Kohler parts. I buy most all my stuff there.
There were 2 versions of the K161 one was the "large bore" and the other the "small bore". The large bore takes the same piston as the k181, the small bore has the same bore size as the K141...my 73 has a small bore, and its hard to find oversize pistons for the small bore version...I dont know the measurements off hand, but it has been discussed here before, so a search might yield some results. A common fix for the small bore situation is to simply get it bored out to the k161-181 large bore size and throw in a k181 piston. Have you measured your bore?
http://www.onlycubcadets.net/forum/s...ead.php?t=1854 http://www.onlycubcadets.net/forum/s...ead.php?t=9193 Jeff (teet) |
The large bore is a 2.938
I think it's the large bore. The bore is at least 2.94.
Am I right in that the original spec is for 2.9380? I think the bore was measured with a dial gauge at 2.94-something. I'm going to the machine shop tomorrow. Should I get it bored out for a 0.10 oversize piston? Is the oversize piston supposed to be 2.9297 + 0.010? I am looking at page 1.6 of the Kohler Engine Service manual. THanks, |
The Kohler K series service manual lists the maximum std bore diameter to be 2.941....so if your 2.94 "something" then your engine should be bored .010 over, and the corresponding piston/rings installed. Make sure you bring the new piston/rings with you so the machinist can fit them properly.
Jeff (teet) |
The machine shop will have to have the new piston in order to bore the cylinder to the correct spec. They can't do it without it. They can correctly measure the bore with a cylinder bore gage and get the exact measurements and then see if it is in or out of factory specs. I would download the Kohler manual if you haven't yet. It has all the specs listed. I would also take the crank to the shop and let them mic the crankpin and then you will know if it needs to be turned or not.
EDIT: Teet is faster than I am.. LOL |
Thanks for the advice. Where should I get the piston and rings?
Should the new governor be a replacement of the existing one? I've never taken one of these apart.
A good machine shop will be able to order all the parts for you and do all the machining plus give you some good tips. I would talk to the shop before they started work to make sure they know what they are talking about. |
