-   -   149 dies on steep incline (https://www.onlycubcadets.net/forum/showthread.php?t=921)
rfrank 06-17-2009 08:03 AM
I put my duals on my 149 so I could mow the hill, just as I'm almost to the top, it dies in typical kohler fashion( no warning just a backfire and done) Im like hmm thats the way it dies when its out of gas. I know it has a full tank. I roll it back to the closest horizontal area and voila it starts right back up. So I guess It was too steep and the way the carb float is mounted it shut off the fuel. Guess I should mow the steepest part going down hill only. Is there a way to adjust the float to prevent this. There is no obstruction in the fuel lines and I donthave a fuel filter on it.
rfrank 06-17-2009 08:15 AM
duals
Here are the duals and the spacer I made until I can get the ag tires I want.
RPalmer 06-17-2009 08:54 AM
You must have been on that hill for some time. I always shut off my fuel and run the engine till it stops when parking it. And I am always ready to go in the house before the carb runs dry. Recovery time on this is almost instantaneous.
toyman 06-17-2009 10:32 AM
That's a good idea, especially for those of us who don't have everyday use. Another thing to be aware of with splash lubricated engines and hills (more sidehill than up and down) is that not only can you rob the engine of fuel, but also oil. That situation can be deadly to an engine. Just a thought!
Oh, and the duels look great!
young enthusiest 06-17-2009 10:42 AM
speaking of lack of oil, a guy who runs a small engine shop told me this. a guy was running his 149 on such a slope, that he rolled it a couple times. once he figured out how to mow without falling over, he punced a 6 inch hole in the side of his block. he wrecked the rod, piston, cylinder, cam, and anything else he could find in the crank case. not exacly the brightest person. Oh, I LOVE the duals. can't wait to see the ags mounted.
rfrank 06-17-2009 04:55 PM
When mowing the same hill with my other tractor (18hp Murray) the front wheels want to come off the ground a bit, so I have to lean forward. So yes, it is a bit of a steep hill. I mow it late in the afternoon after the dew is off or I'll not make it up. I've never checked to see what degree incline it is. I try not to mow anything sideways on the hill for the very reason of splash lubrication.
