-   -   serial number problem (https://www.onlycubcadets.net/forum/showthread.php?t=9035)
jrr cub 03-02-2011 04:11 PM
Hi, can anyone help with this. I have 128 the serial number tag is located on on the left side of the frame next to the clutch pedal the serial number reads *2050045u507961* now the only tag i can find on my 124 is located on the rear end housing next to the hitch. the tag number is *291871* something does not seem to be right because if this is correct the 124 is newer than my 128. and i don't see how that is possible. is there another tag and where is it located on my 124? thanks:bigthink::bash2::bash::Help::Huh:
R Bedell 03-02-2011 04:31 PM
2050045u507961
The 205 indicates it is a Garden Tractor
The 0045 indicates the actual model
The "U" indicates it was made in the USA
The 507961 is the actual sequential serial number.
Thus, the 124's serial number is 291871 and the 128's serial number is 507691.
jrr cub 03-02-2011 06:36 PM
serial number
:Thanks: R Bedell for that help this clears things up now i understand how it works. :beerchug: :High5: :ThumbsUp:
