A bit more progress on the K321
Carb mods have started.
The pos subject for drill test. Walbro 52 http://i5.photobucket.com/albums/y19...wagon/pos1.jpg Hole looks good, now on to the carb that is gonna go on the K321. The Walbro 64 Factory jet. http://i5.photobucket.com/albums/y19...n/factory1.jpg Holley jet after drill and tap. http://i5.photobucket.com/albums/y19...holleyjet1.jpg Walbro 52 vs Walbro 64(on right) http://i5.photobucket.com/albums/y19...agon/52v64.jpg Walbro 64 (on left) vs Kohler 26 http://i5.photobucket.com/albums/y19...agon/64v26.jpg I know David Kirk was able to get a Walbro 52 apart and bored out. I was gonna try this till I got the 64's. But I noticed in my drill test if you go this route you can use Holley jets to get more adjustment. The jet will block the passage of the original needle valve. http://i5.photobucket.com/albums/y19.../drilltest.jpg A few shots of the M12 Crank M12 on bottomhttp://i5.photobucket.com/albums/y19...gon/cranks.jpg M12 on top after machining PTO end for my clutch. http://i5.photobucket.com/albums/y19...gon/crank2.jpg http://i5.photobucket.com/albums/y19...gon/crank3.jpg http://i5.photobucket.com/albums/y19...gon/crank5.jpg http://i5.photobucket.com/albums/y19...gon/crank4.jpg And an inexpensive GM door spring tool that works great for Kohler valve springs. http://i5.photobucket.com/albums/y19...doorspring.jpg |
I used that same door spring tool to remove my valve springs... Works great! Cheap too at the parts store. Or well it was many years ago. LOL
They Still Are!
