-   -   Help (https://www.onlycubcadets.net/forum/showthread.php?t=8983)
Duster72 02-27-2011 12:39 PM
Help
Got the 125 with a k241 running It runs fine at half throttle if you give it full throttle it back fires out the carb.
Duster72 02-27-2011 01:24 PM
We put new points in it . Will check the timing .think you
mmzullo 02-27-2011 05:33 PM
Wild Bill is on the right track. Check the timing. Hows the valve lash? By the way lets see your Duster!
Here's mine.
Duster72 02-27-2011 06:53 PM
I would put a pic on here if i could I'm using an iPad. But it is a 72 340 4 speed.
young enthusiest 02-27-2011 08:57 PM
From ipad pic posting is easy. Put the pic on the photobucket app (free) then paste the IMG code into your post on here :)
Duster72 03-01-2011 08:36 PM
Ok guys I set the timing . It runs better but it still back fires out carb.
_DX3_ 03-01-2011 09:53 PM
Condenser or coil??? Try a new condenser first.
