-   -   Push button starter (https://www.onlycubcadets.net/forum/showthread.php?t=8158)
Lonestarcub 01-10-2011 07:57 PM
Push button starter
Has anyone ever tried using this push button starter from Tractor Supply?
it looks like the same as the one sold for the Cubs and it calls for a 1 3/4"
hole opening which should fit.Just curious...it cost 12.99.
Thanks,Bruce
Yosemite Sam 01-10-2011 10:36 PM
I'm sure it would work and be a good quality part but the button sticks out about twice as far past the dash as a factory one.
Sminkey 01-10-2011 10:43 PM
You could make a shim for it so it doesn't stick out so far. Good find!!
juniors1282 01-10-2011 11:09 PM
Ive got one in my "O" it works just fine. It does stick out to far, but works just fine. Here's a picture so you can see what it looks like. Oh and it does use the same mounting holes.
ACecil 01-11-2011 12:20 AM
I had a 100, that had the longer push button starter. Never had a problem with it.
Monzaman78 01-11-2011 05:39 AM
I also have the same button on my "O" it works great.
Matt G. 01-11-2011 10:38 AM
I had that on my 100 that I restored. It worked great and was rated for 12V.
Yosemite Sam 01-12-2011 12:03 AM
Capital idea! Simkey, I didn't think of that.
garnold 01-21-2014 08:57 PM
Did you try shimming this out? What is the advantage of this, just not turning the key?
Cubby guy 01-21-2014 09:02 PM
A few of the early Cubs had a separate starter switch, rather than the 3-position key switch. (Off-run-start)
