-   -   Quiet line brakes (https://www.onlycubcadets.net/forum/showthread.php?t=8033)
Tim S. 01-03-2011 05:28 AM
Quiet line brakes
Does a 1650 or any of the quiet lines have an internal brake, are they a wet brake or is the braking done with the transmission.
Tia, Tim
chris 01-03-2011 05:57 AM
brakes
i have seen and had some quite lines with internal brakes and they are wet setup
steveyrock 01-03-2011 05:59 AM
Hi Tim
I just picked up a 1250 and it has external mechanical disc brakes like my 106 narrow frame.You can see them from the back at the axles on each side.I didn't know some may have internal brakes so I learned something new.
Yosemite Sam 01-03-2011 11:06 PM
I don't know for sure but I thought the gear drive Q/L's had internal brakes and the hydro models had external. I could very well be wrong though.
nashcub 01-03-2011 11:49 PM
I have had several QL series tractors. Seems like the earlier models all had external brakes.
The four QL's I have now all have internal brakes. Two 1450's, a 1650, and even the 1200 gear drive I have, are internal brake. They are all 78-79 models.
I have no idea if IH optioned internal/external throughout the run, or if they all were internal after a certain serial #.
ACecil 01-04-2011 12:27 AM
I owned a 1975 1250, and it had external brakes.
Willie Schmidt 07-22-2011 10:37 PM
My April 1977 made 1250 has internal brakes.
cub1450 07-22-2011 11:11 PM
I had a 1978 1450 and a 1975 1000 both had external brakes.
jeff967 07-23-2011 09:00 AM
I do not know her year model, but my 1200 has external disks.
bignastyGS 07-23-2011 09:38 AM
My 1200 has internals and the 800 we have has internals.Both of the 1450's we have and had have externals. The 1250 also had external brakes.My 128 had externals,but I swapped to internal brakes as I like them better..
