-   Tractor pullers using Cub Cadets! (https://www.onlycubcadets.net/forum/forumdisplay.php?f=12)
-   -   Frame Cracking? (https://www.onlycubcadets.net/forum/showthread.php?t=7313)
JOHN SCHUTTE 11-16-2010 09:07 AM
Frame Cracking?
I have heard that a frame can crack when high hp motors are used for pulling. Has anyone run into this before? My 1250 frame is now down to bare metal and I want to do any welding or reinforcing that needs to be done. I plan to get about 50-60 hp out my motor and was wondering if reinforcment is needed at that hp level. Thanks, John Schutte.
JayBrd 11-17-2010 04:09 PM
John, I know the CCO's crack where the frame mounts to the tranny reduction housing. I would guess the WF's (as well as the NF's) would crack around the tranny mounting areas. The would be the area I would think would not be allowed to flex.
JOHN SCHUTTE 11-17-2010 04:37 PM
Thanks Jaybird, that was kinda inline with what I was thinking too. :bigthink:
Matt G. 11-17-2010 05:36 PM
Every cracked NF or WF frame I have seen has been around the axle C-channel.
jesse682 11-17-2010 06:56 PM
I've heard of them crack right before where the steering column bolts to the frame too.
hillbilly 11-18-2010 12:02 AM
I don't think the intention is to use a hydro? Am i correct. We had reinforced reartrans mounts on account of the fact our transmisions were pitched down about 2 or 2.5" in the back bolt hole. (the front mount bolt in recuction housing stayed the same.) I think the prostock had a custom crossmember in the front for the motor to bolt to. Dad built a square tube axle that was welded to a pair of frame extensions.
JOHN SCHUTTE 11-18-2010 11:29 AM
Yes, I plan to use a manual transmission. Not to change the subject, but will a NF transmission bolt up to a wide frame?
ACecil 11-18-2010 12:11 PM
Yes, it should. All the gear drive cubs used the same transmission.
Yosemite Sam 11-18-2010 12:14 PM
Yes, the only difference (that I can think of right now) will be that you will need the brake linkage/s depending on external disks or internal brakes.
hotya100 11-18-2010 02:30 PM
John, I am running a narrow frame internal brake rear end in my 1000 puller. The tractor originally had external brakes. You won't have any trouble installing the rearend. I also haven't noticed any cracking of my frame, but we had to make an engine cradle to install our twin cylinder Kohler. We usually do an annual inspection after pulling season to check everything over. Good luck to you.
Larry
