-   -   Will not move in any gear (https://www.onlycubcadets.net/forum/showthread.php?t=62537)
Elliot 08-24-2024 10:27 AM
Hi I have recently redid my 104 ,installed a creeper gear and now it will only move in creeper mode.I adjusted clutch as per manual but not sure next move,the thought of breaking it down is taking the fun out of this
jbrewer 08-24-2024 01:08 PM
Very nice looking cub! I hear you about having to do stuff over again (and again). I think we've all been there.
Not sure exactly what the issue might be (nor if the creeper worked before and suddenly quit now, or...)
This video might be helpful:
https://www.youtube.com/watch?v=95KJ...nesMotorsports
Let us know what you find.
Elliot 08-24-2024 02:57 PM
Thanks for the video, but my problem is the creeper works it shifts into all other gears but doesn't move
darkminion_17 08-24-2024 03:40 PM
Did you put it back together correctly? You may have the shift collar on backwards.
jbrewer 08-24-2024 03:47 PM
Yup!! That would do it too.
I didn't mean this was the exact problem you have but that it shows the correct operation of the creeper when engaged and disengaged which might be a help visualizing what the issue is with yours.
Elliot 08-25-2024 07:51 AM
Thanks for the info , I was told that creeper should be in high to use regular gear box. I have the creeper shifter in between hi and low thinking that was neutral
jbrewer 08-25-2024 09:09 AM
And best of all... YOU DONT HAVE THE SPLIT THE TRACTOR AGAIN! :-)
Elliot 08-25-2024 10:13 AM
Thanks again, amen to that
