-   -   CC129 Brake and Neutral Linkage setting (https://www.onlycubcadets.net/forum/showthread.php?t=61870)
TractorRick 01-19-2024 07:57 AM
I previously posted before I was having an issue with Brakes and Neutral, After digging into the guts with a schematic I notice many parts were missing, most importantly the linkage between the pedal and cam. The PO used a bent rod and wire. I ordered parts and the install seems straight foreward, My only question is, Does the linkage needs a certain span or do I lock the pedal all the way down and adjust accordingly? If the weather holds up I plan to dive into it tomorrow. The part I am reffering to is highlighted in attached picture. Thanks
West Valley G 01-19-2024 08:43 AM
I think the service manual probably does a decent job and how to
set the brake ( which has to be done first) and then the neutral for the
hydro.
https://s3.us-east-2.amazonaws.com/c...ervice+Man.pdf
Ken
