Zach77 |
04-11-2023 10:19 AM |
2018 XT2 EFI Won’t start after stopping
I have a 2018 Cub Cadet XT2 with the 679cc fuel injected engine. When I first fire it up it starts as it should and will run for a couple minutes and die. After this happens it will crank but will not fire until around 5 minutes later. It will do this 2 or 3 times and then runs completely fine with no issues. Does anyone know what this could be? It has the push key ignition module, I changed it out to a new one but did not fix the problem. Thanks in advance.
