-   -   38 Inch Deck Overall Width? (https://www.onlycubcadets.net/forum/showthread.php?t=61085)
IH Cub Cadet 04-07-2023 10:25 PM
Anyone know the overall width of the 38 inch mowing deck used on the 109 IH Cub Cadet? Trying to fit the tractor and deck through a basement door to get it out of the weather.
Don’t have a deck yet, but considering one. Any tips to lookout for when buying one of these decks?
Any sage info/advice is much appreciated.
ol'George 04-08-2023 07:37 AM
Well the easiest way to measure is with a tape measure across the deck.
If you are talking a normal walk through door they are max 36"
if the deck is off the tractor it will fit through any door easily standing it on its side.
Now getting the tractor through the door is a whole different ball game.
But I'd be more concerned getting it down the basement steps! :bigeyes:
Might be easier to get a small portable outside tarp shed.
Shelter logic at tractor supply makes nice ones inexpensively :bigthink:
finsruskw 04-08-2023 07:41 AM
Leaving a tractor outside, under a tarp is not a good idea.
athomas 04-08-2023 09:58 AM
you can add about 3 inches roughly to the cut width for the overall width
to be in the ballpark ! :beerchug: I also wouldn't recommend covering with a tarp outside as it just traps moisture !
ironman 04-08-2023 10:50 AM
2 Attachment(s)
Pictured is the underneath of QA 38". The cutting width is 38" tip to tip of the outer blades.
You can get a rough idea of the total width with overhang.
R Bedell 04-08-2023 10:53 AM
This is what the guy is asking, for a pending purchase !!!!
darkminion_17 04-08-2023 11:53 AM
A 38" is 45" and a 42" is 49"....
R Bedell 04-08-2023 12:03 PM
Thanks Lew.
