-   -   Snowplow blade edge cover (https://www.onlycubcadets.net/forum/showthread.php?t=60846)
Graflex45 01-24-2023 08:40 AM
I cant seem to find it on this forum again, or was it on another? There was a tip to cut a slot along a length of iron pipe to make a blade cover for plowing on gravel drives so the blade doesn't dig in.
Anyone remember this post or done something similar on their snow plow? what gauge pipe? does it really work well?
I don't have metalworking equipment so i'll need to draw out a good description and get a welder or someone else fabricate it for me
I got to use the plow on the 1450 the first time yesterday and the driveway at my new house is very rough and in desperate need of regrading and redoing with crushed stone in the spring...
Radioguy41 01-24-2023 08:57 AM
This one?
https://www.onlycubcadets.net/forum/...highlight=pipe
Farmall450 01-24-2023 08:27 PM
Make sure it is in snow mode (unpinned so that it can trip). I have the shoes on mine like a "real" snow plow which help with that a lot.
Graflex45 01-25-2023 08:54 AM
Originally Posted by Radioguy41 (Post 523303)
Thanks I hadn't thought of pvc pipe, that makes it cheaper and better in case it bumps into the edge of my concete walkway
Graflex45 01-25-2023 08:58 AM
Yep i have it unpinned so it can flex on the springs if it snags something, what do you mean by the shoes in the real position? if i slide a piece of pvc pipe over it should the shoes not be below the line or should they?
Farmall450 01-27-2023 10:01 PM
Something like this I fabricated for mine.
https://www.amazon.com/Cub-Cadet-703.../dp/B00CSCCJO8
Just like a real snow plow.
