-   -   Operation advice? (https://www.onlycubcadets.net/forum/showthread.php?t=60834)
Martin 01-22-2023 07:55 PM
Operation advice?
Hey there,
I finally got this Covid project 124 up & running.
My problem is grinding the gears and clutch timing.
High & low ranges work, sometimes smooth as silk.
Others, not so much. I’m wondering if my shift change technique needs improvement, or maybe clutch adjustment? Should I be double clutching, or other.
Any advice will be welcomed.
Thnx.
Tim.E 01-22-2023 10:12 PM
Are you trying to shift gears while moving?
The gears are not synchronized,,,,,,,,,,I.E. you can't shift them on the go, you must stop the tractor to change gears. Sometimes even then you must roll the tractor forward or backwards just a bit to get it to slip in gear.
Thats just how it is with old tractors.
Martin 01-23-2023 10:58 AM
Thnx Tim.
I’ll try to be more purposeful and slow things down?
Sam Mac 01-23-2023 12:36 PM
Yep keep shifting while moving and soon you'll be asking about how to rebuild the transmission.
