-   -   Is it normal for a hyrdo tranny to whine? (https://www.onlycubcadets.net/forum/showthread.php?t=60796)
hamman88 01-11-2023 08:05 AM
I got my Paquette's 127 running real smooth after some carb work and a rewiring. I have never owned a cub cadet before and was somewhat surprised by the whining the tranny makes when in gear. Kind of annoying since the engine sounds so good. I would say it louder at slow speeds, but it might just be the noise of going faster that covers it up.
Is this whining normal? I wouldn't describe it as incredibly loud, but the pitch and volume does make me want to grab headphones when riding it. Hydro fluid is topped off.
1711Cub 01-11-2023 08:24 AM
Some whining is normal. If it is considered excessive, it could be cold temp related, or poor quality fluid, and a clogged filter. I would ensure that the fluid and filter is fresh and full.
I recommend Case IH Hytran and an OEM filter.
hamman88 01-11-2023 09:23 AM
It is a 10 year old OEM filter on it with I'm assuming almost no hours. Fluid is about half 10 year old hy-tran, half brand new generic for IH from Rural King. There was a leak from a lose fitting I fixed and then topped it off.
R Bedell 01-11-2023 10:30 AM
It is NOT uncommon, for off brand hydraulic fluids to make the Sundstrand Hydro whine a bit, especially during colder weather. The whining fades away when the temp of the oil becomes warmer.
Tim.E 01-15-2023 08:52 PM
Are you running your engine at full rpm's ?
The hydro seems to whine more if you are not running your engine at full rpm's.
