-   -   cracked head? (https://www.onlycubcadets.net/forum/showthread.php?t=6025)
tservice 08-25-2010 07:29 PM
cracked head?
I pulled the head off my 127 today. I think it is cracked.... is it???
Matt G. 08-25-2010 07:49 PM
How are we supposed to tell with a 3" wide picture? Clean it up and look at it closely.
eralbert 08-25-2010 08:44 PM
Sometimes it's not what you say...but how you say it!!
Get a flat surface and some fine grit sandpaper and sand it till the metal shines....use a wire brush on a drill or some tool and clean the carbon off....the cleaner the better to see any flaws you have.
Hope this helps.....if your camera has a macro function, make sure your camera is stable and will not move and take another pic so we can see better ...and close up
fer100 08-25-2010 09:37 PM
there is a easier way to Clean the head. spray the head with easy off oven cleaner let sit for 10 min, wipe off and repeat. Use a brass wire brush for the harden areas. Then use sand paper. go over it inch by inch to check for cracks.
johncub7172 08-26-2010 02:35 AM
I myself have not seen "white" under a head like that. Like eveyone else is saying....clean it up as new and see if you can see a crack. What makes you think it is cracked anyway?
tservice 08-26-2010 08:22 AM
Time for oven cleaner :). I think it is cracked because I have never seen a shiney spot on a head before, and there looks like a crack in that spot. But I don't see anything wrong on the ouside of the head.
tservice 08-28-2010 10:06 AM
All cleaned up. It appears that the head was once cracked and has been repaired.
