-   -   149 relief valve lever (https://www.onlycubcadets.net/forum/showthread.php?t=6019)
ab147 08-25-2010 08:44 AM
I bought a 149 this summer and the part that pushes down on the relief valves is gone from the relief lever. Anyone fabricate one of these, or can they be bought?
R Bedell 08-25-2010 08:58 AM
You have two avenues to pursue.
(A) The parts you are looking for are NLA new from Cub Cadet. You could try looking for good used parts from the Sponsors listed in the boxes at the top of the page.
You could also try here..........Parts
(B) You could replace the Manual type of Relief Valves with the newer Automatic type.
Matt G. 08-25-2010 09:14 AM
(C) I don't see why you can't make one if you've got the tools. It's just a piece of steel that wraps around the lever and is attached with a roll pin. The original one is spring steel, but if you're gentle with it, you won't bend one that isn't spring steel. It takes very little to hold those buttons down.
TEET 08-25-2010 10:29 AM
Scroll down...they are towards the top of the page
http://ihccw.com/drive.html
Jeff (teet)
ab147 08-26-2010 07:01 AM
Thanks for the help guys
