K321 head and tin assembly
I posted this to the forum before and never got a definite answer. Assembly drawings DO NOT help
I need to know how to assemble the head and cowling on top of my k321 like the gas tank mount etc. Mine has head studs which are still in plus a few head bolts. I need to know where any spacers go. I found 4 spacers. I think I have everything needed to put back together. A picture would help. |
You make NO mention of the Tractor Model you are working nor the complete Kohler Model either.
:Huh: |
A accurate and complete Kohler model number would be like this: K321-60226. This fine tunes and can accurately answer your question(s).
Its K321 A. Looks like 2257311 maybe |
3 Attachment(s)
Hope these pics help ! this engine has all bolts ,but if you got studs usually there would be a spacer over the stud to fill the void in the head then your tin baffle would sit on top of the spacer then the washer and nut ! these studs would all be out in front of the fuel tank mount which sits on top of the large blower housing ! :beerchug:
Pictures of what you have such as the top tin and muffler shield would help.
I will get a pic but correction. I have 4 studs and 5 bolts and 4 spacers |
| All times are GMT -4. The time now is 02:08 PM. |
