-   -   Diff Carrier Bearings (https://www.onlycubcadets.net/forum/showthread.php?t=59164)
SS5150 08-17-2021 09:19 PM
Anyone have a cross reference for Cub Cadet 741-0369 and 741-0400? They are the rear diff carrier cone and cup for Original through 2182. I've got a fine spline carrier with damage to the cone & cup on the ring gear side so I'd like to replace both sides if I could.
Thanks
ol'George 08-18-2021 07:22 AM
Make sure you check the lash between the ring and pinion and re establish it with the new bearings installed. otherwise it will howl about 45 MPH. :biggrin2:
But seriously it needs to be within range, or excessive gear wear will result.
Dart1917 08-20-2021 12:15 AM
Get them out and the numbers should be on the parts. Probably Timken.
