-   Kohler Engines (https://www.onlycubcadets.net/forum/forumdisplay.php?f=50)
-   -   Piston ring types - production vs service (https://www.onlycubcadets.net/forum/showthread.php?t=59115)
RustyShackleford 08-04-2021 06:09 PM
2 Attachment(s)
Hi all,
I searched around for an answer to this but came up dry, so forgive me if this has been asked and answered before. I have a piston and ring set for a K241 (part number on the box is 47-874-01) and the part number on the ring set is 235287. The rings look like the attached photo. I haven't seen such a ring set illustrated or really talked about much at all in any of the service manuals I've seen. The closest thing I've found is a brief reference in the old K-series service manual I have (Rev No. 4-72) on page 11.2 (a screenshot is also attached).
Perhaps these are "service" rings? I just had the block sleeved and bored to STD so I am wondering if these are fine to use :bigthink:
Thanks as always for the help :beerchug:
R Bedell 08-05-2021 07:05 AM
OEM's often come out with a design for a part, then after years, there comes a new replacement part that is suppose to be an improvement, for various reason.
If you ran the "original part number" and Kohler supersedes it, then I would go with that, and follow the instructions contained in the replacement parts box.
RustyShackleford 08-05-2021 06:18 PM
2 Attachment(s)
That's about what I figured, thank you!
I have been referencing the parts manual (IH-TC-113) made available by MTD. Based on that document (screenshots attached; pages 4 and 6 respectively of Section D) I got the part numbers for the piston and rings (which came as a set under the piston assembly part number). It's surprising how much of this stuff is still available NOS if you look around.
I mention the above in case someone else reads this thread and finds this information useful :)
