-   -   Locked in gear (https://www.onlycubcadets.net/forum/showthread.php?t=58987)
littletractor 07-10-2021 09:08 AM
Locked in gear
I have just a cub cadet 124. Engine runs great, clutch works great, my problem is the transmission keeps getting stuck stuck in second gear. I can remove shift lever, break the gears loose, replace the lever and it works fine thru all gears, than will suddenly lock up again. Help
dale c. 07-10-2021 12:30 PM
pull the shifter off the top , it'll probably be easy to see the problem
littletractor 07-10-2021 04:41 PM
Thanks, what will I be looking for?
ironman 07-10-2021 06:15 PM
You will take out the 8 bolts that hold the shifter plate to the top of the transmission case. The shifter and plate will lift up and out as a unit. Looking down into the opening you will see the two rods (Number 17), and the two shifter forks (numbers 14 and 18).
The two shifter forks are held in place on the rods buy the bolts (numbered 12).
I would venture a guess that one or both of the number 12 bolts have become loose or fallen out, or your shifter fork may be broken or bent.
littletractor 07-10-2021 06:49 PM
Thank You very much
littletractor 07-11-2021 05:55 PM
Fixed
Thanks for your help, fixed it this morning-runs great
ol'George 07-11-2021 06:06 PM
What did you find as the problem? :bigthink:
green407 07-11-2021 09:47 PM
^^^ This. ^^^
ol'George 07-12-2021 08:29 AM
Originally Posted by green407 (Post 510946)
^^^ This. ^^^
What you posted, or if a pix, it didn't come through.
green407 07-12-2021 11:38 AM
I just quoted you ol'G. I too am curious about the cause of his cubs problems.
