Finally picked up some attachments
4 Attachment(s)
230 miles later and the Quietline has more to do than just plow.
Attachment 108233 Love this old girl but I didn't fire it up for years since I got a walk behind snow blower. Looked on and off for attachments locally and kinda gave up for awhile. Well after a little gas and a new battery we spread 12+ yards of dirt with the plow so I decided to start hunting for parts again.... now down to hunt for a tiller and the sleeve hitch height adjustment parts I think I tapped a vein... I want another one lol I mounted the deck up just to see how everythine went together and to test the pto. Need to tear the deck down to grease and shapen, also appeared the center pully was flipped upside down when mounted. Attachment 108234 Couple of questions. This cub had a 12 hp swapped in place of the 10. Is that double pully on the PTO correct? Also is the deck hanging right on the front? Guess I assumed it would make it past the notch on the height adjustment bracket. Everything seemed to work fine just making sure I'm not missing anything. Deck is a 44a. Thanks. Attachment 108235 Attachment 108236 |
Nice score. It is always good to add implements.
:ThumbsUp: |
2. I personally have not come across an electric pto with a double pulley like that on a Cub, but if it does not interfeere with anything and works, then AOK. 3. Yes, the deck looks to be mounted correctly. The front mount hangers do not go past the "notch". |
Just curious - if the deck is mounted correctly, what is the purpose of the "notch"?
Again just a theory.:bigthink: |
Never heard anyone refer to it as such before. If it works, don't worry about it. |
Nice find and I bet your return trip with the implements was a lot more fun than getting there. Now, maybe your walk behind will collect dust in the corner while your cub gets some attention.
Cub Cadet 123 |
I just had a thought that, perhaps the 2-pulley electric PTO is off a 200 series John Deere. The setup of those machines is in a way that you need 2 different belt pulleys whether you want to run a mower deck, or if you want to run a front-mount attachment like a snowthrower. The inner pulley would be for a mower deck, and the outer for a snowthrower.
Or, you say the whole engine was replaced, so perhaps you have the complete engine and PTO from a Deere 212? Just throwing out a couple ideas. :bigthink: |
Nice haul! Now you just need two more tractors so you don’t have to change implements all the time. :biggrin2:
