-   Welcome to OnlyCubCadets (https://www.onlycubcadets.net/forum/forumdisplay.php?f=2)
-   -   Model & Year Help (https://www.onlycubcadets.net/forum/showthread.php?t=58612)
viaminveniam 04-23-2021 02:19 PM
Model & Year Help
3 Attachment(s)
Hi Everyone,
My name is Nick, and I am a new member / first-time poster. I have been charged with restoring a Cub Cadet that has been sitting idle for nearly 20 years. I was hoping that you all might be able to help me identify the Model and Year...
Known Information:
1) CHSI Serial #: 351530-R7
2) KOHLER Engine: Model No: K161; Spec No: 2853E. Ser No: "?"-600752 ("?" is a Letter designation that is covered/scratched out... A=1965, B=1966, C=1967, D=1968, E=1969).
3) Please see the attached pictures.
Thanks, everyone! & Thank you Mr. Bedell, for suggesting this approach!
-Nick
bill682 04-23-2021 03:05 PM
That is a Cub Cadet "Original"
351530-R7 is the part no. not serial no.
Your Kohler spec no. is likely 28542E
Chassis serial no. is located here.
https://www.tractordata.com/ltphotos...al-960x720.jpg
R Bedell 04-23-2021 04:52 PM
The Original was made from Oct 1960 to Aug 1963. The serial number will pinpoint Month & Year.
:IH Trusted Hand:
viaminveniam 04-23-2021 05:23 PM
Thanks Bill682 & R Bidell!
As for the serial #... bummed I read that wrong. That part # is in the same location that Bill682 noted the serial # should be. In fact, I don't recall seeing any other identifying markers in that area?
Perhaps...
1) The tractor isn't all original?
2) The "L2", which is stamped in that same location -see pic- means that part should be on the left side and not the right? I do recall my Boss noting something about his son, years ago "hot-rodding" with the tractor. He ultimately dropped the transmission. They replaced the transmission... maybe that part is interchangeable with the other side, and they just mixed it up?
I will look for a serial # again.
Thanks again!
finsruskw 04-23-2021 07:32 PM
The serial number is STAMPED into the side of the case in the location indicated.
You may have to scrape or wire brush some paint off to locate them.
IF you are LUCKY, it will be a low 4 digit number!!
Those numbers you pictured and referred to are CASTING NUMBERS
You have been "charged" with restoring it??
As in someone hired you to do it?
R Bedell 04-23-2021 07:46 PM
The Serial Number range for the Original is: 590 - 65547.
ol'George 04-24-2021 07:48 AM
is it possible that casting is from a Farmall cub tractor, as it is mentioned it had been replaced???:bigthink:
bill682 04-24-2021 07:55 AM
The serial number is stamped on the reduction housing. The Farmall Cub did not use a reduction housing.
ol'George 04-24-2021 01:34 PM
Thank you, I forgot that.:bash2:
viaminveniam 04-26-2021 08:09 AM
827H... could this be the serial #?
