-   -   Trunion springs specifications (https://www.onlycubcadets.net/forum/showthread.php?t=58573)
RLause 04-15-2021 11:59 AM
Does anyone know what the specifications are for the trunion springs. It seems like I have seen the information before, but doing a search on the web and on here turned up nothing. I would like to test mine before I order new ones. Thanks in advance for any help.
cooperino 04-15-2021 12:08 PM
Not sure I have ever seen a spec as in how many pounds of tension etc.
R Bedell 04-15-2021 12:21 PM
Can't say that I have also.
:bigthink:
Workingstiff 04-17-2021 10:35 AM
Why do you think you need new?
poellot 04-17-2021 10:53 AM
I cannot tell you specs. But... there should be just a very little compression to put them in. With new springs it only takes your fingers to compress enough to get them in. The middle spring compressed first until the outside spring contacted, then just about 1/16 to 1/8 tops i would say on my new oem springs when putting them in.
RLause 04-17-2021 04:39 PM
My 782 seems to jerk more than it should when I shift from forward to reverse. Shifting from reverse to forward seems to work smoother. The trunion corners are in good shape and the springs look OK.
Billy-O 04-18-2021 08:16 AM
Turn the spring around and see what happens!:ROTF1:
