Installing amp gauge on 122
Hi guys,
I purchased a amp gauge and bracket for my Cub Cadet 122. I can't seem to find any info on how they wire into the electrical system. |
Go to the Technical Library section for Tractors, and look at the Wiring Diagrams on page #5.
nothing shows up when i try to click on the wiring diagram
2 Attachment(s)
Here's the 122 diagram:
Attachment 106756 Here's the diagram for the next tractor series (which came standard with an ammeter) Attachment 106757 All the wire colors are the same between the two. The green wire runs to the neg. terminal on the ammeter rather than going directly to the solenoid. Then an additional red wire (not original to the 122's harness, you'll have to add that wire) runs from the pos. terminal of the ammeter to the same solenoid terminal where the green wire would have gone. Hope this helps :beerchug: |
Here is a simplified diagram. |
| All times are GMT -4. The time now is 11:52 PM. |
