1641 with Briggs 16hp
Does anyone still have a copy of the service manual for the 16 hp eng used on the 1641. Need a copy if still available. Trying to find the correct valve lash adjustments. Thanks
Valve clearance is .004 intake, .006 exhaust.
Roll the crankshaft clockwise when viewed from the flywheel end until the piston is TDC. Continue until piston is 1/4" down in the hole. Adjust the valves. |
