-   -   Question on Snow Blade Latch Pins (https://www.onlycubcadets.net/forum/showthread.php?t=56824)
rlriii13 04-22-2020 06:13 PM
I've been on the lookout for a blade to add to my 1440. A local Craigslist add turned up a blade that the seller thinks will fit on my 1440. When I compare the latch pins with those I see in the attachment guide though, they're facing different ways.
I've never known the difference. Will pins that face outward like this fit a 1440?
https://i.imgur.com/Rk37uKa.png
R Bedell 04-22-2020 07:26 PM
You will need the proper Snow Blade Mount as pictured below.
rlriii13 04-22-2020 07:36 PM
Right, that's what I see in the manual. So, then what frame type do the pins in the photo fit? The seller said he used it on a 582.
R Bedell 04-23-2020 07:47 AM
The Snow Blade frame pictured is the IH built IH-549068-R2 Blade Frame for Wide Frame IH built tractors.
rlriii13 04-23-2020 09:21 AM
I see. Thanks for the education Roland! I was under the impression from Googling around and from looking at the 1994 Attachments Guide that cyclops and wide frames could share the same plow. I didn't realize the IH sub-frame for wide bodies was different. I guess I'll keep looking for a 190-375/376. Thanks!
Cub Cadet 123 04-23-2020 11:03 AM
Just post in the "Wanted Section" of the forum in the category "Trading Post" for what you are looking for. You never know what might turn up!
Frank1541 04-24-2020 08:12 AM
Check the Service Bulletin in the tech library section. There is one on using older sub frames on cyclops tractors. It may apply to your situation.
Mike McKown 04-24-2020 09:18 AM
I have an older blade like the one in the picture. Someone adpated it to a Cyclops simply by using two pieces of flat stock and two pieces of round rod and fabbing up just like the illustration.
rlriii13 04-24-2020 10:55 AM
That makes sense Mike. I don't know if I'm up for the extra project right now though. Got a photo of what yours looks like?
Mike McKown 04-24-2020 11:08 AM
No I don't. That illustration should suffice if you decide to make your own brackets.
