rear axle problem?
i am changing the axle seals, and axle bushings on a cub original. the problem i have is that i have a little bit of play in the axle in and out. if you put a jack under it you can push and pull the axle about 1/16"(just guessing).is there a way to fix this problem, or is a little bit of play normal. i looked up the parts breakdown and there are diff. bearing retainer shims. is this what i need to take out the play, and if so, how do i measure which shim i need? they are expensive ($20 each) so i would like to only do this one time and do it right. thanks:American Flag 1:
Original axles are held in the axle tubes with snap rings, if the end play is excessive and you're concerned about it, get your best measurement and go to your local bearing supply store and get some 1" id thrush washers in the closest thickness to your play. Probably cost a couple bucks each. Your snap rings could also be worn a little thinner than they originally were, you may want to replace them.
Unless it's really bad I probably wouldn't worry about it. |
its not bad, but like i said, if you jack up one side, you can move it in and out a little. the snap ring looked ok. the only reason i even pulled it apart is because there is a little weep hole on the bottom side of the left axle tube that was starting to drip oil. i figured that i only wanted to do this once. sorry, i went back and read your post and think i understand what your telling me to do. so put the thrust washer right below the snap ring, and that should take out the play?
Yes, LMAO I'm sorry, I didn't tell you what to do with the washer once you got it. I'm pretty stupid sometimes!
yea, i got it all apart and kind of figured thats what you meant. thanks again
| All times are GMT -4. The time now is 07:50 PM. |
