-   -   PTO won't disengage (https://www.onlycubcadets.net/forum/showthread.php?t=5540)
Richs72 07-29-2010 02:01 PM
PTO won't disengage
Model 72 - the front PTO is stuck engaged. It's not like it was engaged and it wouldn't disengage, I had just started the machine and even though the lever was to the rear the clutch was engaged and will not disengage.
edw 07-29-2010 03:39 PM
pto clutch
two things come to mind.Is the pto wear button on the pto arm in good shape.Second try tightening the turn buckle adjustment to a shorter length.
Richs72 07-29-2010 10:10 PM
I looked at those. When you put the lever in the forwaard position the clutch mechanism doesn't move so it appears to be locked up. I tapped it with a hammer and a rusty like powder came out. After 42 years maybe it's time to rebuild/replace it.
Yosemite Sam 07-29-2010 10:34 PM
I would check the buttons first.
I think we need pictures...
