-   Customized Cub Cadets (https://www.onlycubcadets.net/forum/forumdisplay.php?f=11)
-   -   Wide frame gear drive with hydraulics? (https://www.onlycubcadets.net/forum/showthread.php?t=54914)
austinewald 04-25-2019 04:57 PM
Hey I am looking for info on adding hydraulics to a gear drive. If I decide to do this, I would like mine to look clean. I found pictures and info about scott m's 1706 so this gives me a rough idea, but leaves out a few problems.
He didn't say where his pickup line was, so would you just tap the bottom of the trans and put a fitting there?
If anyone else has done this, I would like to see some pictures of it done.
Thanks, Austin
Randy Littrell 05-22-2019 07:01 PM
I believe I have seen the rear cover being used for pickup and return. You might try searching on google for pics, but I know I have seen it done.
Randy
austinewald 09-10-2019 09:43 PM
I've came across this photo and many others. Only downside would be no creeper gear as the pump would interfere
https://i.imgur.com/990pIjx.jpg
ol'George 09-11-2019 08:32 AM
Thanks, Austin
The rear cover could be used but I'd put the return line in the oil to keep foaming to a minimum.
But with as little GPM's we are talking about it might not be a problem,
and one is limited due to the small size of the reservoir.
austinewald 09-11-2019 09:34 AM
I think the tranny has a drain plug at the bottom, could make the suction line there. And on his return line and pressure line, He tapped it at the shifter cover as shown here.
https://i.imgur.com/RG5y34Q.jpg
Merk 09-11-2019 02:12 PM
The size of the reservoir shouldn't matter on a closed hydraulic system. I would drill and tap the side of the transmission or reduction housing. Add a fitting for suction and return.
R Bedell 09-11-2019 03:23 PM
the size of the reservoir shouldn't matter on a closed hydraulic system.
I agree. My concern would be the pump, with focus on the Volume and Pressure.
finsruskw 09-20-2019 11:38 AM
Procure a side mounted pump such as used on the DanCo loaders.
Operated via a belt off the accessory drive pully on the rear of the engine.
DanCo added a pully to the rear of the OEM piece and used the right side tower as a reservoir.
cooperino 09-20-2019 11:47 AM
Operated via a belt off the accessory drive pulley on the rear of the engine.
DanCo added a pulley to the rear of the OEM piece and used the right side tower as a reservoir.
I agree. I was going to suggest last week a GM Saginaw power steering pump with built in reservoir.
I'm not sure he has the pulley on engine but one could be added I'm sure.
finsruskw 09-20-2019 01:42 PM
That may prove to be rather bulky I would think.
Plus you would have to be careful where and how you mount it so as to not be in the way of the rams or frame uprights.
I sure like the compactness of the DanCo set up
