-   -   A Hopeful Score (https://www.onlycubcadets.net/forum/showthread.php?t=54536)
johncub7172 02-21-2019 12:54 AM
A Hopeful Score
Well, if all goes as planned, much later today I'm in hopes to have found a Kohler M18! Guy says it ran when parked, and is being delivered! This will go good next to my KT17, lol!
mickb72 02-21-2019 09:27 AM
Good luck. I have one in my red 582 that came out of a Sears with a 1" shaft that the Briggs pto bolted right to. Mike:beerchug:
johncub7172 02-22-2019 01:31 AM
Thanks,...…….but...…
Turns out to be a Kohler 17 Series Two, and not the m18. Oh well. I still like the engine! Its out of a Ford LGT 17, I'm figuring. The later Ford garden tractors came with the M 18's.
Ill post more tomorrow!
ol'George 02-22-2019 07:59 AM
Not a lot of difference in the series 2 vs the magnums.
The series 1's is where the low pressure splash connecting rod oiling, caused early demise.
Magnums have a magneto ign. instead of points/coil on the series 2, and other small changes internally were made.
They were basically a slight upgrade in a good 2nd design before the production of the opposed flathead twin ended.
Still my favorite opposed twin.
R Bedell 02-22-2019 08:26 AM
IMHO, I would agree also.
johncub7172 02-24-2019 10:04 PM
That's good information and opinion, thanks! So, because of the two cylinders, the Series 1 must have been more fragile as opposed to the single cylinder Iron Line Kohler's ?
Tractor Data lists the Kohler 17 twin at 691 cc, and where as the Kohler Mag 18 is also listed as a 691 cc engine.
johncub7172 02-24-2019 10:16 PM
3 Attachment(s)
Here are a few pictures. I got the engine for $80. The guy I work with sold it to me, and said it ran fine until the mower deck was shot, and the driveline was gone. He kept the 17 hp and scrapped the rest of the tractor. Says this engine is out of a Ford garden tractor that had a 60" mower, but could not recall what model. I looked at Tractor Data, and seem to believe this engine could be from a 1983 -1986 Ford LGT-17. I also got the dash with all instruments and controls, along with the engine wire harness.
Upon first glance, it appears to me that the engine base ( engine mount locations ) looks identical to the other Series Two I have - said to be from a IH 782 ( in favor of a Mag 18 ) . However, the flywheel appears different when looking at where the Cub drive hub would mount. A side from the actual flywheel plastic screen, my best guess is that all engine tin and components are not missing.
Thank you gentlemen for your response, and looking!
