-   -   682 electrical saftey switches (https://www.onlycubcadets.net/forum/showthread.php?t=5438)
tukn20s 07-21-2010 01:37 PM
The PO of my 682 wired a push button starter button because he said the iginition switch was bad. Well after some playing, I found out the switch is not getting the proper power. So either there is a bad wire or another problem.
The electrical diagram I have shows two saftey switches, one being the pto seat switch. Can anyone tell me where the 2nd switch is and what it does?
metalrain 07-21-2010 04:36 PM
Its probably the neutral safety switch...brakes gotta be depressed for it to start... (try that first) Just follow your brake pedal connections. If i remember, mine is located center of the tractor between the frame, you might be able to see it with the tunnel cover off.
metalrain
