Flat, Semi, or Gloss Black on a Cub Cadet 1450 Resto. ?
I am in the middle of restoring a Cub Cadet 1450 Quietline and am planning the painting stages and colors of each part. I am trying to determine which type of black will look the best on all parts to give the best "clean" appearance. I will be mixing the paint with a hardener (I have proper PPE) and a reducer, so this is not rattle can. I have been searching for pictures to compare but I really haven't found much.
(1) So far I have the following list of parts to be painted black. Please let me know if something has been omitted or if there is a part you think would look better black. I realize they painted them all together at the factory, and I want to clean the look up a little and be more detailed.
Also, either on each part or overall together; which shade of black do you think will look the best? Flat Black, Semi-gloss Black, or Gloss Black? . . |
I used "Satin" black on my 1450.
Yes, Satin is like a semi-gloss. Tractor tucked away for the winter. Won't dig it out now until April.
I think I will go with a Semi-gloss black on all parts to be painted black.
The big question is......what about that aluminum dash tin? I want to restore it similar to others where they polish, mask, paint, and apply decals to the lettered areas. Should I go with Semi-gloss black on that or gloss black? I just want it to "pop" and look as nice as possible since I'm going to the trouble anyways. |
| All times are GMT -4. The time now is 10:20 AM. |
