Rear brakes
I have a 1450 with external brakes and I’m looking for some options/suggestions bond the pads, because what I have seen there are very few and expensive!
Did you try here ?? Link: Brake Pads
Shouldn't be that expensive. McMaster Carr has the material for next to nothing...
Just follow the link and instructions above. Really simple process assuming all parts on your tractor are present or in working condition. |
Rear brakes
Thanks for the advice and I just read the post on re-lining the pads right before seeing this! Can’t get any cheaper than that!
The McMaster Carr lining is too thick by about 1/16"
You will have to shave it down on a belt sander to get it thin enough to fit. |
| All times are GMT -4. The time now is 02:11 AM. |
