Cub Cadet 125 Hydro Issue
My Cub Cadet 125 is having an issue with the hydro. Sometimes when I stop moving and get off the lawnmower to do something I’ll leave it running and then it will start to either creep foward or backward on its own. This doesn't happen all the time, usually when its been running for a while.
There is an adjustment procedure in the service manual. Basically, put the rear end on jack stands, start the tractor, put it in neutral via the brake pedal. The tires will probably rotate one way or the other. Carefully loosen a couple bolts on the front left side of the hydro and tap the cam pivot bracket up or down a bit to make the rear wheels stop moving. Tighten the bolts, try the forward/reverse control several times, stepping on the brake. Readjust as needed to get true neutral when you put the brake pedal down.
If you don't use the pedal, then just use the control handle to stop the tractor from drifting when you stop. |
it is a safety thing to put the brake on when you leave the tractor, or shut it off, but you still have to set the brake or it will roll downhill. |
