-   -   1450 Key Switch Harness Melted - What Causes It? (https://www.onlycubcadets.net/forum/showthread.php?t=53985)
AL Farmall Boy 12-03-2018 02:16 PM
2 Attachment(s)
I've noticed that this seems to be a "common" issue with this model Cub Cadet (from reading on the internet). Do any of you happen to know what causes this? Since I am tearing the tractor apart and restoring it, I want to not only fix what is wrong but make sure it doesn't happen again. Going to replace the switch, a new pigtail, and what else?
I've also got to figure out what that green wire goes to that the Previous Owner decided to splice into for the melted terminal on the switch harness.
mattoney 12-03-2018 02:19 PM
This wiring diagram may be of benefit to you.
https://www.onlycubcadets.net/forum/showthread.php?t=22
cooperino 12-03-2018 02:39 PM
Heat build up like that is typically caused by a short or something drawing to many amps like the starter. The starter is the only thing in that tractor that draws enough amperage to do that unless you have headlights. They would be the second thing.
Loose or dirty connections can also cause more current draw
finsruskw 12-03-2018 03:43 PM
Corrosion on the contact terminals from being left out in the elements for YEARS and YEARS!!
R Bedell 12-03-2018 04:06 PM
Causes, as mentioned prior.
Course of action. (A) Replace the Ignition Switch. (B) Chop back 4" to 6" until you get "clean" copper wire, then patch in each individual wire with a .250" Female Spade Quick Disconnect connector 14-16GA Crimp (Blue).
Gompers 12-03-2018 04:21 PM
Electric pto on a 1450 is a fairly big draw too.
cooperino 12-03-2018 04:24 PM
:bigthink: I thought PTO was on just a 10 amp fuse?? From the looks of the connector I would think it had more than a 10 amp draw.
finsruskw 12-03-2018 05:03 PM
Pull the switch and check the back side of it.
I'll bet it's all corroded causing heavy drain to make connection, thus the heat that melts everything.\As with everything electrical, connections and terminals ALL need to be bright and tight. A little dab of dielectric grease will help also but will draw dirt and dust
If it were mine, and a keeper, I'd spring for a new harness and a new switch and be done with it
AL Farmall Boy 12-03-2018 05:56 PM
Thank you! I actually printed that one the other day and stuck it in my IH service manual.
AL Farmall Boy 12-03-2018 06:03 PM
Yes back of the switch is rusty. I'm replacing the switch and getting a new harness plug pigtail and will wire inline so it looks and functions as factory correct. I will heat shrink the butt splices. I just wanted to make sure that there wasn't a common problem like too small of gauge battery cables or a bad ground point for the engine that would cause it. Someone I was talking to told me that since these engines are rubber mounted and have a dedicated ground cable that when it corrodes or gets a bad connection it will melt the key switch harness. I just want to make sure it doesn't happen again.....or at least not again for another 15-20 years.
