Asking to confirm
I found a narrow base cast iron pan on feebay the other day for a much better price than I have seen in a while. Thing is that it came off of a "green" tractor not a yellow one. Was there anything about a Deere narrow base pan that would make it not work for a cub? Have it in mind to go onto a 1200.
Nobody????
At least one of the cast iron pans I've used on my Quietlines came off a JD. If it's a deep sump and looks just like the aluminum one it will be fine- I think
Dart, that's what I was thinking,(and hoping) it does look similar, it does have the half round sump protrusion for the rod dipper like the aluminum sumps that I have now... didn't know if maybe they were different depths or something in that half round portion.….. I know some were flat as well... this one that I found, isn't.
I didn't expect my post to be an extension of the bash-fest that was recently closed, but I have been curious as to whether he would be allowed back, or if he will come back, even if allowed. I was wanting to ask, but didn't want to start another bash fest...so let this be the end of Jon talk on this thread. |
No guarantee it won't leak though.
Last one I bought off the bay was cracked and made a mess of my brand new restored 149 engine bay 1st time out. Examine it very carefully before you install it. under edit: This was a cast iron pan to boot |
Ask the seller for the part number cast in the pan, should be one there.
Sorry I can't answer your question dodge trucker but if that one doesn't work out try sending member dvogtvpe a PM. He may have the correct pan for your project. :beerchug:
One can NOT answer the question because the initial information is very limited and vague.
IF........you could get the Kohler "Model & Spec" of that engine, one could look that up and see if it applicable to the Cub Cadet Kohler K301AQS - 47541. Right now, it is all guessing and speculation. :bash2: |
I tried to ask while the sale was live for this pan, you guys were asleep so I took a chance. USPS tracking says it's now about 70 miles away, so I'll have it in hand tomorrow and I'll post the cast in number. I do have another aluminum IH/CC Kohler pan here so I can compare it to once I get it here |
| All times are GMT -4. The time now is 04:00 PM. |
