149 Headlights
What lights from Harbor Freight did you put on your 149? I'm painting mine and want something cheaper than O.E.M.
Thanks |
The OEM headlights that IH/CC used was the #4411. It can be had at any Auto Parts Store and numerous places on line.
See if Larsen lights can switch over the sealed beam number Roland posted (I think that's a pretty standard item) to LED, you won't regret it if you plan on working at night.
I think the original thread that was dug up was referring to tail lights. If so I think these have been used.
https://m.harborfreight.com/automoti...air-93227.html |
Any 12 VDC PAR36 bulb will work. You can get them most anywhere. Home improvement stores have them in their landscape lighting section.
IF, you are looking for the Rear Lights, then you will need: IH-545616-R1. They are NLA from Cub Cadet, so online searching will be needed..
IF, you are going for aftermarket, just about any "marker light" will work. |
