-   -   Cub Cadet 100 Headlight Wiring & Switch (https://www.onlycubcadets.net/forum/showthread.php?t=53305)
cnewell 09-09-2018 02:23 PM
I’ll be adding a headlight assembly to my Cub 100 and I keep seeing in many of the wiring diagrams a fuse as part of the set up for the wires between the light switch and the starter switch. Where do I get this fuse section? I’m not finding part numbers or anything and it didn’t come with the new wiring harness hat I bought. I bought the additional headlight wires and it’s not in there either.
Also, where is the best place to install then switch on the steering tower? Mine doesn’t have a hole pre-drilled. Anything special about the IH-62801 DCP switch?
mortten 09-09-2018 03:42 PM
https://www.onlycubcadets.net/forum/...ead.php?t=4639
cnewell 09-09-2018 07:47 PM
Instructions
Thanks Doug! I had no idea those instructions existed. Thanks for sharing them!
