-   Cub Cadet Lawn Tractor (LT) (https://www.onlycubcadets.net/forum/forumdisplay.php?f=42)
-   -   Engine Swap Exhaust (https://www.onlycubcadets.net/forum/showthread.php?t=52922)
mairhead 07-27-2018 05:24 PM
Engine Swap Exhaust
I have a LT1045 that's about 10 yrs old. It had a 20HP Kohler Courage SV600-0009 that had the loose bolt/cracked case problem. I held it together with JB Weld for a couple of seasons, but it got to the point where I couldn't control the oil leaking any more. I replaced it with a 19HP Briggs & Stratton Intek 33R877. The engine runs fine - the only problem is that the previous exhaust pipe does not fit correctly. Does anyone know of a "stock" pipe that will work? Does anyone know of a supplier of flexible exhaust pipe that I could scab in place of the old? My neighbors seemed concerned that I am mowing with no hood on the tractor. Just looking for a solution to this minor problem.
Thx.
ironman 07-28-2018 08:46 AM
Thx.
Here's somwhere you can start....
https://www.google.com/search?source....0.4-qXJbq4zX4
cooperino 07-28-2018 08:55 AM
Cut a hole in the hood and put a stack on it! YEEEEHAWWWWW!
