-   -   Under deck paint (https://www.onlycubcadets.net/forum/showthread.php?t=52112)
Workingstiff 05-12-2018 01:27 PM
Under deck paint
I sand blasted the deck last year. I used the TSC ?alkyd? primer and paint. The top/outside I'm happy with the under side not so much. What can I use under there that holds up? Not a super huge fan of Rustoleum. Its ok but there has to be better...
ol'George 05-12-2018 01:40 PM
Well some fellows have tried EZ slide, it is a graphite paint and it is suppose to keep the grass from sticking.:bigthink:
Now if it is a trailer Queen not many people are laying on the ground to inspect the bottom of a deck, so most anything mopped on it would be just fine.
I used a couple of gallons on a Gravity wagon so high moisture corn would slide easier, and was pleased with the results.:beerchug:
Bsmith 05-12-2018 01:44 PM
I like to use SlipPlate. Did the bottom of this 48 GT deck with it.
Workingstiff 05-12-2018 02:16 PM
I'd love to be able to make this a trailer queen of sorts. But, that life isn't for me,lol. It's my work horse. My buddy that farmed in to his 20's would chuckle and correct me when I called it a tractor. He of course called it a lawnmower. He changed his thoughts after he's been through a couple of Craftsmen and Huskee. I'm still running it after all those years. And lets resume our paint conversation!
Workingstiff 05-12-2018 03:10 PM
Thanks for above info.
Sorry, I should have explained myself.But, thats not what I'm after.
I'm not worried about "slickness". In the HIGH flow areas the paint is basically gone. There's some chips taken out else where. I'm interested in a little bit more durability.
twoton 05-12-2018 03:16 PM
First.....
twoton 05-12-2018 03:17 PM
.....and then...
twoton 05-12-2018 03:18 PM
:ThumbsUp:
CADplans 05-12-2018 08:54 PM
What can I use under there that holds up? .
The main thing that causes the blades to "wear" is the sand/grit that is sucked up by the mower, and propelled out of the discharge,,
So, in effect, each time you mow, you are sand blasting the underside of the deck
So, to answer your original question, I gotta ask,,,
"When you sand blast, what type of paint remains behind? :bigthink:"
THAT would be the paint to use!! :clap:
:biggrin2:
ol'George 05-12-2018 09:10 PM
Expecting paint to last under a deck, is like expecting a moldboard plow to keep paint on the shares,shins & moldboard.
It ain't gonna happen.:beerchug:
