-   -   107 electric lift (https://www.onlycubcadets.net/forum/showthread.php?t=51709)
Countryboy5191 04-04-2018 02:13 PM
107 electric lift
I have a 107 and just picked up an electric lift for it, my questions are, how hard is it to make a 147 rockshaft work with the 107, and also what is needed to connect a snow blade lift rod to the electric lift. Just trying to get my ducks in a row before installing the lift.
olds45512 04-04-2018 02:18 PM
The 107 and 147 are basically the same tractor so the rockshaft will go right in.
Countryboy5191 04-04-2018 02:19 PM
Thank you!
sir_lancealot 04-04-2018 06:32 PM
You will need to fab up a bracket for the front of the e-lift to attach to the frame. The 147 was built with the bracket on the frame flare. If you go to page 6 (PDF Page 11) of the below manual, it will tell you how to rework the implement bracket to work with the e-lift.
http://ccmanuals.info/pdf/Front%2042...l%20Manual.pdf
Cub Cadet 123 04-05-2018 06:26 PM
That's a good lookin' 107 there. Be careful getting that Armstrong lift out of it. Hint: Never cut what you can untie!!!:biggrin2:
