-   -   4 Circuit Hydraulic Setup (https://www.onlycubcadets.net/forum/showthread.php?t=51455)
samckitt 03-07-2018 08:35 PM
Bringing old post back to life.
What about 4 different cylinders? How would you do it? Run 2 - 2 spool valves, or a triple & single?
Rescue11 03-07-2018 11:41 PM
:biggrin2:
Ten characters
Edit: THIS HOW http://www.onlycubcadets.net/forum/s...t=31710&page=5
samckitt 03-08-2018 08:08 AM
Didnt read through all of it, but what I did read sounds like a 3 spool valve with a diverter solenoid to redirect to a different cylinder...?
J-Mech 03-08-2018 08:56 AM
Yes. Pretty easy.
It would do you good to read the whole thread. Maybe you wouldn't have any more questions.....
R Bedell 03-08-2018 09:50 AM
This is my suggestion....
J-Mech 03-08-2018 10:04 AM
As long as you don't want to use more than one at once, that would work. But in that set up, the first valve takes priority.
R Bedell 03-08-2018 11:14 AM
That is true IF....you are using more than one valve at a time.
Let's see, One hand on the Steering Wheel, and One hand on a valve, probably be OK.
RLause 03-08-2018 11:27 AM
The JD valve I used was a Dukes valve. I found the literature and have included the link here. Hope maybe it helps someone.
http://qccllc.com/sites/all/themes/m...Model-1627.pdf
J-Mech 03-08-2018 12:12 PM
Unless he's building a backhoe. OP doesn't state the intent. Which also makes it difficult to answer the question. Doesn't matter. He asks stuff like this all the time. Never shares anything that gets built.....
Plus, if you go by the thought that you can only operate one valve at a time because you have to have one hand on the steering wheel, then you wouldn't be any good at running a loader. You have to tilt the bucket while lifting or you will dump the load. Should be able to rum at least 2 at a time. 3 if they're positioned right.
Rescue11 03-08-2018 02:11 PM
Ever done That? A tripple spool is tough enough to squeeze into that cowel. Would think that would be next to impossible to do while retaining an authentic look
