Wheels- dumb question
Did IH change the bolt pattern on a 23x8.50-12 between models? I.e. Would the wheel from a 129 fit on a 127?
Thanks |
AFAIK....The only thing changed was the "width" of the rim.
For a 23 x 8.50 - 12 tire: 127 takes a 734-3004 Wheel 129 takes a 734-3004 Wheel |
Should be same wheel.
They changed the way they counted the holes though...
They are all a 5x4.5” pattern. I’ve ran the same wheels on my 100,126,& 149.
Oops...should have said 23x10.50-12...but that still doesn't matter that works.
For 23 x 10.50 - 12 Tires:
127 uses 734-3013 Wheels 129 uses 734-3013 Wheels |
Hey Daniel. C'mon, you know there are no dumb questions here. So, here goes my question.....you listed that you have only one, a 149, did you get another one? A 129 or 127?
Cub Cadet 123 |
| All times are GMT -4. The time now is 02:16 PM. |
