-   -   147 Timing Question (https://www.onlycubcadets.net/forum/showthread.php?t=51246)
smokeman 02-06-2018 07:10 PM
147 Timing Question
Hi all, can you guys give me a walk through on the timing/ points setting on a 147 . I looked all over that flywheel shroud for a hole to find the timing marks but I don't see it anywhere. were they different on a 147 ? I rolled the engine to what I think is TDC on the compression stroke with the plug out. The pin pushed the points out and I set the points with a .020 feeler. Coudn't get it to fire. WTH am I dong wrong ? Thanks Smoke
smokeman 02-06-2018 07:30 PM
I found the hole guys, I was looking on the side of the shroud. That thing is really tucked in behind the starter/gen. I give it a try tomorrow and see if I can get it going. I don't have a timing light. Can I just rotate the flywheel to the S mark and set the points at that location ? Thanks
J-Mech 02-06-2018 07:31 PM
Read this:
http://www.onlycubcadets.net/forum/s...ad.php?t=33461
smokeman 02-06-2018 07:47 PM
Originally Posted by J-Mech (Post 445788)
Thanks Jonathan, I actually found it and:beerchug: was reading it right before I came back to this post. I am surprised that you didn't hear me saying thank you for posting that info. I don't have a timing light but I do have a test light.
J-Mech 02-06-2018 09:49 PM
:IH Trusted Hand:
sawdustdad 02-07-2018 08:47 AM
If you don't have a test light, you can use a multimeter set on "continuity." That's how I do it. That way, you don't need the engine hooked up to a battery so it's useful during rebuild assembly.
smokeman 02-08-2018 08:17 PM
Thanks Sawdust, I have both the test light and a multi meter. I think my father in law has a test light that I might borrow to dial it in good.
J-Mech 02-08-2018 08:20 PM
A test light, or a timing light?
Leave the timing light in the toolbox. This engine has no advance on it. Static timing like I outlined is the best method.
smokeman 02-09-2018 03:24 PM
Jonathan, I am having one hell of a time getting this engine timed. When I do the test light way, I cant even get the thing to fire. I'm sure that I am doing it wrong. When I get the SP in the port hole, It seems that I have to rotate the crank or flywheel about 3" before the test light lights. I cant get the test light to light on the SP mark. The cam rod comes out farther, then it lights but by then I am past the SP mark. Could my flywheel be off ? When I use a feeler at .020, I can get it to fire but I am no where near the SP. I hope I am making sense. Thanks, Smoke
J-Mech 02-09-2018 04:35 PM
Set the SP mark in the window, then using the test light, adjust the points to just break contact and light the light. You have to adjust them. Forget the feeler gauge.
If you don't understand the article I linked to, then I can't help you. I laid it all out in as simple terms as possible in the article.
